Home > Faults & Fixes > Battery change on 2008 TDV6 |
Who checked the battery? Do they have an interest in selling you a new one? The AA are very quick to condemn every battery they test because they want to sell you an overpriced replacement and most other organisations are no different. Try charging the battery fully with a proper smart charger first and see how it goes.
Tue Jan 09 2018 12:05pm |
Green Spyghs Member Since: 25 Jul 2017 Location: Barrow Posts: 2 |
I've had a similar issue myself @rayb22, it's worth spending a bit of time looking through all the fuses - this was my first port of call, to no avail. Next I would check your back seats are folded down as this will ensure the wiring assembly card is flush with the PCB board. With regards to your procedure request, I have found the 'in and out' technique works best for me but make sure the cars running hot first. Worth noting, B&M are doing a manager's special on AA batteries until Monday - so you get a move on as you don't want to be... 'over-charged' (battery pun) Kind regards, G |
Tue Jan 09 2018 12:48pm |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
@Green Spyghs
Wed Jan 10 2018 10:40am |
Classic 2008 MY Java Black TDV8 HSE
Wed Jan 10 2018 11:41am |
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 |
Had to get a new battery for my '08 RRS last year - Advanced Battery Supplies seemed to do the best price and even took back the 'too long' Varta and replaced it with the correct 'shorter' version at no cost! 2008 RRS HSE Stornoway Grey |
Mon Jan 29 2018 4:53pm |
