Home > Technical > Gearbox fault |
No sorry but this will push you back to the top |
Sun Jan 07 2018 9:34pm |
cmec Member Since: 01 Nov 2014 Location: In the Middle Posts: 20 |
Hi had a similar problem with my previous model sport, dealers explaination was that they did something with the control software and that fixed it. Whatever it was it worked. |
Mon Jan 08 2018 12:08pm |
Then it may need a software update from dealer or through an IDD tool |
Mon Jan 08 2018 12:14pm |
The older L320 model can have a known fault with gearbox not changing up that is related to failed or incorrectly fitted stop/tail bulbs (makes the car think it is braking when it isn't).
Mon Jan 08 2018 2:42pm |
Welshian Member Since: 26 Apr 2016 Location: Staffordshire Posts: 88 |
Thanks for the info Paddi, the car went in its annual service in Nov but prior to that no probs and no work on the brake lights either, although upgrading the front headlights would't go amiss. Makes you think RRS2 HSE Chile Red
Tue Jan 09 2018 11:42pm |
Ahh. I see That explains it. Couldn’t understand why a bulb could cause so many random faults in the rest of the car’s systems. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Wed Jan 10 2018 11:00pm |
