Home > Faults & Fixes > Same old GPS issue
motormate
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Same old GPS issue
Hi, my GPS has the red line issue. I have gone into the hidden gps diagnostics menu and it shows plenty of activity and also have changed to an aftermarket aerial which seems to be the main issue for most people just to see is that is the issue, but no.
So I have a signal, have tried a new aerial oh and I am in the middle of Belgium after hitting the reset button in the hidden menu.
The disk is around 2015
Hidden menu self and auto check does not come up with any faults
As I say the menu shows that there is plenty of sat activity using both aerials
And still a red line, and in Belgium Laughing
Admittedly the gps is pants but I like to keep the car up to scratch so its better than nothing
Plenty of dvd drives on ebay at stupid prices but if I am confident this is the issue I would buy one
Time for a change soon and am considering another newer one although they do have an above average breakage record
Post #544969 Sat Jan 06 2018 6:38pm
phillh
I seem to recall when I upgraded mine, it reset to Belgium.
I just had to change the location in the settings menu and it worked fine.
Post #544982 Sat Jan 06 2018 8:18pm
Eaters
I’m with phillh here. Had the same issue with my old Jag which had a similar system. I think the default is set to Belgium and needs to be sorted via nav settings Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #544999 Sat Jan 06 2018 10:55pm
motormate
I have reset the location to UK and I'm still in Belgium
The issue is the gps red line and resolving this. Once it is working of course it will identify my position. Why if I have a good signal and no faults have I got a red line through the gps icon ?
Post #545012 Sun Jan 07 2018 9:32am
geoffsnook
Well if it has a red line through the gps icon the unit is not getting a signal so there is a fault or a cable unplugged somewhere Thumbs Up
Post #545013 Sun Jan 07 2018 9:36am
motormate
No Censored Rolling with laughter thanks anyway
I suppose I am looking for some guidance from someone who has had a similar deal. I mot sure if I want to shell out over 150 for a refurbished dvd if somehow there is a function that has been turned off that is not obvious
As the dvd has the gps function inside the box it is possible that this could be the issue or has anyone had this with a bad disk ?
Post #545033 Sun Jan 07 2018 1:26pm
geoffsnook
Well no Censored cant help but the dvd mech is know to go down but not producing the no gps signal the sat nav usually freezes and will not work i had to replace the insides of mine with a new optical drive but if you say you have a full signal something is telling a big porky again faulty disc's normally just freeze the system
Post #545035 Sun Jan 07 2018 2:10pm
motormate
I've heard that it could be worth carrying out a hard reset by taking off the battery leads etc but not sure if this is for the car of this year. I have a IID tool too which gives me full access to the cars ecu's and I guess this does a hard reset too ?
I love the car but there is always something, now and then where my Jap car has never had an issue in its 15 year live save for the normal replacement parts, not even a bulb has blown.
Maybe time for a change though I have heard that the new models are no different and can crack turbo pipes etc as the Jag does which shares the same engine
Still this is not getting the gps fixed and I can go without it to see if it miraculously fixes itself
Thanks to all who dip in and out as it is always helpful to hear your comments and don't stop adding your comments as it may trigger the fix
Post #545042 Sun Jan 07 2018 2:46pm
geoffsnook
Never hurt's to do a hard reset or post on the Disco3 site as there are quite a few people on there as well as on here plus more who may have had the same problem Thumbs Up
Post #545051 Sun Jan 07 2018 4:08pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
when i replaced my GPS module i went through the whole process, full of joy that i'd done it, fired up the car and the same red line through GPS. just unplugged the cables again and re inserted them. all good after that. 2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #545147 Mon Jan 08 2018 7:52am
motormate
Did you have the same issues ? When you say unplugged and re inserted do you mean into the new gps unit ? One thing I have not done is taken th power cord out of the gps just the fakra and usb
Anyone got any suggestions on where to get a refurbished denso unit ? I see all these ones on ebay and who knows if their dvd drives are in good order too.
Post #545153 Mon Jan 08 2018 9:19am
geoffsnook
Are you sure the usb plug is in the correct way as i know when i fitted my gvif it is possible to put it in upside down Thumbs Up
Post #545167 Mon Jan 08 2018 11:24am
simonmanx
United States 2008 Range Rover Sport 4.4 V8 HSE Stornoway Grey
hi I have a 2008 res and looking to update the GPS etc whar sre my options ?? I'm in california usa
Post #557126 Tue May 22 2018 7:17am
simonmanx
RRS not red
Post #557127 Tue May 22 2018 7:18am
motormate
Well I never did get it going again. It was the straw that broke the camel's back. To be fair new or old RRS are renowned for their mechanical and electrical quirks so I made the decision to change the car and bought a 6 months old Audi Q7. Certainly hasn't got the immediate curb appeal but the drive and build quality is superb. Goodbye niggling troubles.
Post #557129 Tue May 22 2018 7:39am
