Home > General > Foggy Headlights |
Andy, I would guess that on a 2005 car your headlamps are not totally sealed as per the description by RRSTDV8 above.
Wed Jan 03 2018 2:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
In the 80's and 90's we used the completed seal headlights.
Wed Jan 03 2018 6:55pm |
Chunk11 Member Since: 02 Jul 2017 Location: Manchester Posts: 47 |
I am hoping if I can remove a lot of the moisture then that will solve the issue but will keep you updated. I think there maybe too much moisture for the natural venting system to handle so I am thinking if I can get as much as I can out then hopefully the light unit will be able to handle what is left?! Range Rover Sport 2010 3.0 TDV6 HSE in Black
Wed Jan 03 2018 9:10pm |
Right all set for tomorrow’s test. I have a rather large number of silica gel sachets and have tied a piece of string so I can retrieve them easy enough. I was going to try it this morning without but realised I could only just about fit my hand down the back of the light unit.
Sun Jan 07 2018 9:02pm |
