Home > Faults & Fixes > Head rest DVDs
Wynne1991
Wales 2005 Range Rover Sport TDV6 HSE Siberian Silver
Head rest DVDs
Hi new to this forum I have a 2005 sport the DVDs in headrests turn on , insert dvd and it just says loading for a while and then says no disc ? Any help thanks
Post #544279 Thu Dec 28 2017 9:51pm
geoffsnook
are you playing the correct disc for the system?
Post #544301 Fri Dec 29 2017 10:11am
Wynne1991
This might be daft thing but what do you mean by correct disc ? I have only tried 1 disc and it is a genuine disc not a copy ! Thanks
Post #544318 Fri Dec 29 2017 2:52pm
geoffsnook
Thats ok then as long as it's not a copy you trying to play try a hard reset disconnect the battery terminals from the battery and hold the positive and negative together away from the terminals you may need to put something metal between them just make sure there away from the battery itself it will reset the system so may work or the dvd may be broken Thumbs Up
Post #544335 Fri Dec 29 2017 7:49pm
geoffsnook
i assume you have used a cleaning disc on them Thumbs Up Whistle
Post #544336 Fri Dec 29 2017 7:51pm
Wynne1991
Ok thanks I wasn't sure how to do the hard reset , have got disc cleaner today will try tomorrow 👍
Post #544339 Fri Dec 29 2017 8:39pm
phillh
Silly question I know but I assume you are loading the CD in the rhs boot compartment and not the satnav unit under the passenger seat.
Post #544344 Fri Dec 29 2017 9:34pm
Wynne1991
Load my into the player in the drivers side head rest
Post #544345 Fri Dec 29 2017 9:37pm
PEACHY
Are the screens factory fitted ?
Ps welcome to the forum 14MY Autobiography Dynamic - SDV6 - Fuji White Smile
Post #544346 Fri Dec 29 2017 9:48pm
Wynne1991
As far as I'm aware yes it's a 05 I've on'y recently owned the car , the screen on drivers side opens up to load the disc and can control it off the screen or control panel on drivers side rear door panel
Post #544347 Fri Dec 29 2017 9:52pm
PEACHY
When you say control - can the rear entertainment be controlled from the same screen as your nav - radio etc ?
Do you get this screen ? 14MY Autobiography Dynamic - SDV6 - Fuji White Smile
Post #544348 Fri Dec 29 2017 9:56pm
phillh
My car is 05 and the dvd player (which I believe was factory fit) is in the little hatch on the RHS of the boot.
Are there any maker/manufacturer marks on yours, it could be aftermarket.
Post #544349 Fri Dec 29 2017 10:05pm
Wynne1991
I shall check tomorrow haven't even touched the screen in the front ! Thanks tho
Post #544351 Fri Dec 29 2017 10:20pm
Scrumpy
Mine is also an 05 and others have said the DVD player is hidden in the right hand side panel in the boot. Theres a small door and when you open it you can eject the multi disc dvd cassette.
Are you playing the correct Region disc for your system? --------------------------------------------------------------------------------------------------------
Post #544354 Fri Dec 29 2017 11:40pm
Wynne1991
Maybe mine aren't factory fitted as on the screen in the front I don't have the DVD or rear entertainment option
Post #544358 Sat Dec 30 2017 8:06am
