Home > Maintenance & Modifications > First service warranty wipers?
V8tdi
Wales 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Had my first service yesterday on my My17 l494
Car is 7 months old covered 15k mikes and has the lr service pack
No major work to be done just normal maintainance like oil plus 15 litres of ad blue
Tyres are all plus 5mm even wear one had a nail in it and brakes all fine, three software updates on air suspension, dashboard blackout and oil evaporation I think was the last one
The issue was the wipers
I asked that the rear wiper should be changed as it was simply useless you could see nothing when you used it just a huge smear on the glass
So turns out also front blades needed changing and the dealer tried to charge me for replacement 😡
It was an interesting discussion when they said it was normal wear and tear and not covered under warranty
I guess you can imagine the discussion but on a 7 month old 80k Car with only 15 k miles it’s simply astonishing that they try to do this
In the end they replaced foc but just wanted to raise the point here if any others have the same problem
Post #543904 Sat Dec 23 2017 8:39am
syl
Some would suggest they are replaced every 6-12 months, so wear & tear isn't really trying it on. Then again, maybe they should be on the service schedule, along with aircon regas. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #543906 Sat Dec 23 2017 9:01am
Eaters
Syl would seem to have a point here. If they need to be replaced every 6 months then it should be part of service. They are, after all, a safety item ( well certainly the front ones).
I’ve never heard of it being a service item but then you’d not expect, in practice, to change them every 6 months. More like 1 or 2 years. Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543916 Sat Dec 23 2017 10:26am
ilard
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
I had my wipers changed under warranty when car was 12 months old and 4K miles (years ago now!). I didn’t ask, they just changed them. RRS TDV6 HSE Lux (2011MY)... Nara Bronze / Arabica
Post #543935 Sat Dec 23 2017 2:16pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I struggle to see how wipers can be classed as anything but wear and tear, it just takes some numpty to drag them across a frosty windscreen and then that's them Censored .
Also just 1 sunny summer renders most non-silicone wipers done if i the cars sits outside, they get brittle.
Why should any dealership/garage be responsible for those? 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #543936 Sat Dec 23 2017 2:40pm
ilard
I also had the brakes changed under warranty. Twice. And I barely used them. RRS TDV6 HSE Lux (2011MY)... Nara Bronze / Arabica
Post #543952 Sat Dec 23 2017 4:55pm
