Home > Technical > Wheel nuts again
Gandalf
Wheel nuts again
wheel nuts are a bit shabby plus I want to ditch the lockers so found these
Technical Specification
Thread - 14x1.5mm
Seating - 60° Tapered (Cone)
Hex - 19mm Hex
Material - Heat Treated Steel
Finish - Zinc Plated
will they be ok
Peter If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock)
Think I see a pattern here
Post #543708 Tue Dec 19 2017 11:51am
DrRob
Just get a set off eBay that I and others have tested Thumbs Up
http://www.disco4.com/forum/topic161797.html Visitor from fullfatrr.com
2011 Vogue SE 4.4 TDV8 Full Fat
GONE - RRS SDV6 HSE MY2012 in Orkney Grey.
1993 200Tdi Tdi Range Rover - a proper Rangie!
1949 Series One 80" in family since 1975! Where it all began.....
Post #543722 Tue Dec 19 2017 5:00pm
Gandalf
wanted the solid ones the S/steel capped ones tend to swell http://www.ebay.co.uk/itm/Set-of-20-14x1-5...SwEK9T~fGK b Censored dy cheap though so not sure If it ain't broken down it soon will
Post #543731 Tue Dec 19 2017 6:22pm
wanted the solid ones the S/steel capped ones tend to swell http://www.ebay.co.uk/itm/Set-of-20-14x1-5...SwEK9T~fGK b dy cheap though so not sure
Might be wrong here, but looking at the picture, if it is correct those nuts will not fit the Sport, as the Sport wheels are spigot mounted not tapered cone as those nut's appear to be.
Post #543749 Tue Dec 19 2017 10:01pm
Gandalf
oop's had my blonde head on anyway checked the D3 link and getting these seem well thought of on there. thanks for the link Thumbs Up If it ain't broken down it soon will
Post #543759 Wed Dec 20 2017 10:47am
DrRob
Fitted perfectly on my 2012 Thumbs Up Visitor from fullfatrr.com
Post #543791 Wed Dec 20 2017 5:31pm
