Home > Maintenance & Modifications > 2009 RRS transfer case oil
exopar
Mexico 2007 Range Rover Sport 4.4 V8 HSE Orkney Grey
Dear all
Been digginf the web as well as this honorable forum for info regarding alternative fluids for transfer case in my 2009 RRS as well as the rear diff fluid.
Some say to stay with the OEM and some others recomend so many other options.
Point here is, I have no instant acces to a OEM fluid hence, need to atick with any other sudgested alternatve.
What whould you recomende instead of the comercial oil brands to be fillñed in the transfer case? And rear diff as well.
Regards
Ray
Post #543390 Thu Dec 14 2017 9:24pm
dalmat
Croatia 2006 Range Rover Sport TDV6 HSE Java Black
I had the same problem and while searching I ran onto info about this product
RAVENOL Transfer Fluid TF-0870
http://www.ravenol.de/en/products/usage/d/...-0870.html
It has specification Land Rover IYK500010 needed for our boxes and it is much cheaper.
I hope this could help,
Post #543651 Mon Dec 18 2017 10:34am
shepp
As far as I am aware, there are a few alternatives but they do not have the long life additives of the genuine stuff. It is fine to use the alternatives just need to change the oil more often. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #543665 Mon Dec 18 2017 3:19pm
dalmat
I agree with shepp. This is good alternative when original oil is hard to find or not available, but more frequent change is advisable.
Post #543666 Mon Dec 18 2017 3:28pm
exopar
Ravenol products can not be found in Mexico.
Which other alternatives would you recomend? It does not matter if I need to change fluid more offten tha normjal but need to find a solution.
Post #543688 Mon Dec 18 2017 7:16pm
do you not have any LandRover dealers ?
I expect you will only change the transfer box oil once, so may as well use genuine LR
For Diffs use Castrol
Post #543691 Mon Dec 18 2017 7:23pm
exopar
The only Land Rover dealer available does not supply that fluid neither can order it for me hence need to get any alternative that can be purchased localli.
Post #543693 Mon Dec 18 2017 7:27pm
N60613
Bosnia Herzegovina
Dalmat, have You used Ravenol and if you have how often did you change fluid? Tks.
Post #544319 Fri Dec 29 2017 3:56pm
exopar
Found a direct fluid ap´roved replacement.
Just to let you know guys, Motul has a Gear 300 LS fluid that is Land Rover aporved for transfer case.
Have filled the case in my vehicle yesterday so will let you know my impresion in this regars, however so far so good.
https://www.motul.com/es/es/news/products-...r-changing
Attached a pic at the photo album.
Regards
Ray
Post #544325 Fri Dec 29 2017 5:16pm
dalmat
I just use it after changing bearings and my intention is to replace it after short time to see condition. Anyway, my guess would be to check the fluid regularly and change it a little bit sooner than user manual suggest.
Post #544326 Fri Dec 29 2017 6:12pm
shepp
Motul do some excellent oils, usually far better than the original, just one thing to check is if it has the long life additives. The transfer box can
Cook the oil. If not just Change it approx every 2years. MY12 RRS HSE
Gone 90
Gone s2000
Post #544332 Fri Dec 29 2017 8:08pm
