Home > Technical > suspension problems but no mechanic close by |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Most likely the compressor is failing, unlikely to be the suspension ECU. Be worth checking for leaks using soapy water as a leak could cause the compressor to run constantly. Having said that, a leak would normally cause a corner to drop overnight. A leaky reservoir wouldn't cause a drop, however. Worth checking the reservoir valve block - it's in with the compressor in the plastic box under the the body. 2012 SDV6 - it's missing a couple of cylinders
Tue Dec 05 2017 8:46pm |
rangeymexico Member Since: 05 Dec 2017 Location: London Posts: 3 |
ok thanks for the reply. ill check the valves in the morning. and let you know how I got on. is it worth checking the strut as well. do I just spray soapy water on it to? |
Tue Dec 05 2017 11:23pm |
You'll only be able to check the connection of the air line to the strut. The air bag is enclosed in a metal tube and can't really be checked Insitu. The air bags themselves are pretty robust and unlikely to be leaking. 2012 SDV6 - it's missing a couple of cylinders
Tue Dec 05 2017 11:38pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
It may be worth checking the compressor end cap where the air connections are. It's a plastic cap which can crack between the connectors and causes the compressor to run and overheat. The old soapy water spray will show a leak. It may not be much help to you out there, but there are alloy replacement caps on the 'bay for not a lot of money. remove the compressor cover and it's held on by about 5 screws.
Wed Dec 06 2017 11:12am |
