Home > General (L494) > 20" Wheels ET53 and shims? |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
I have 20 inch wheels and because I run 285/50 tyres needed a 1mm shim I was able to purchase a 3mm AL shim ,Works fine. Was available from local auto store . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Sat Dec 02 2017 2:36am |
Davidsport53 Member Since: 01 Dec 2017 Location: Salisbury Posts: 3 |
Thanks IRBails, will give that a go then, I'm presuming your alloys were 9.5 inch wide? Do you know what the offset was on your alloys? |
Mon Dec 04 2017 8:47pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1239 |
Will 275's fit on a 8.5?, was looking myself but my research led me to believe that 275's are for 9.5s. Might be wrong though
Mon Dec 04 2017 9:12pm |
Hi, the 275's will fit on 8.5 rims but they are a squash and just means the tyre is oversized for the wheel, I did look at doing this as the offsets are then the same but not sure if it's the best idea or not |
Mon Dec 04 2017 10:12pm |
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 |
I replace the tyres which came on the car with BFG 275/55/20 AT KO2s. Needed something tougher. No issues apparent with them after 14000kms. Both on road and off road |
Tue Dec 05 2017 7:20am |
Mine are the previous model RRS mags, load rating was greater than the current model mags . Off set was about 3mm less than standard, can't remember now been two years. They would not rub if I ran a slightly smaller tyre. I also thought they were 10 inch but again not sure now. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Dec 05 2017 1:21pm |
