Home > Technical > 5.0 SC almost stalling after long deceleration |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
Could be the tc not unlocking properly, had a similar problem on a sabb which eventually failed completely and the engine stalled every time you stopped. |
Thu Nov 30 2017 8:24pm |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Thanks for the reply. What's a tc ? |
Thu Nov 30 2017 8:29pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
TC=Torque converter in gearbox |
Thu Nov 30 2017 8:32pm |
Beat me to it lol |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Torque Converter. Actually, the bit he's referring to is a clutch that is used to lock the torque converter and thus give direct drive from engine to gearbox. It gives better response and better fuel economy apparently. 2012 SDV6 - it's missing a couple of cylinders
Ah thank you. I thought it might have meant that, but I had no idea what it actually does so assumed I was wrong. Wasn't aware it could be involved in idling when in neutral. Cheers! |
Thu Nov 30 2017 8:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Not quite the same issue, but the idle on mine sometimes fluctuates when stationary, I think it is related to the air con. if I switch it off it doesn't do it so much but the warmer the air temp the more pronounced it is, not sure air temp would be a factor over there just now. While driving absolutely no problems and no fault codes, doesn't feel like it is going to stall either.
Thu Nov 30 2017 9:23pm |
Happened again yesterday after about 1hr 20 mins. Idling really badly after approaching traffic. Few blips on the loud pedal and all fine again. Didn't happen on the return journey. Are there any other symptoms of a TC or TC clutch issue that I could look out for, by any chance?
Wed Dec 06 2017 9:03am |
Happened 4 times on Saturday while on a 60 mile each way trip. Didn't cut out once, but terrible at idle. Didn't recover as fast as last time either.
Mon Dec 11 2017 10:57am |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 411 |
I had a 4.2 supercharged engine in a Jag. It stalled about twice a year, and threatened to once or twice more. Never found out why. Kept it for about 6 years and 60k miles. Always when the engine was warm and coasting to a stop. Thought it got better when I had the servo replaced, but turns out it don't. RRS MY17 SDV6 AB
Mon Dec 11 2017 4:53pm |
