Home > General > Lumbar Support/Seat Bolsters
shug89
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hello all, i'm here looking for some advice. I have a MY10 sport, and the lumbar support and seat bolsters don't seem to do much when i use the switch on the side of the seat. I can certainly hear something trying to work, possibly a motor, but nothing seems to move!
Had a look around under the seat and checked the fuse, however everything seems ok.
Anyone come across this before?
Post #542208 Thu Nov 30 2017 10:35am
1. There is a leak in the tube or bladder
2. It's working but you don't realise it.
Sit in the seat, resting backwards.
Pump it up for a few seconds.
THen press the other release button, you should hear air escaping and notice the support on your lower back reduce.
If air doesn't escape I think there is a leak.
Do the same with the passenger seat
Post #542230 Thu Nov 30 2017 1:08pm
shug89
I don't notice any loss of air, or any sound of air escaping when i press the release switch.
Also, i went to compare it to the passenger side and it doesn't have the switches for the bolsters and the lumbar support is a manual dial on the side of the backrest. Maybe there is a leak somewhere that's simply not inflating the support?
Post #542259 Thu Nov 30 2017 4:55pm
On jags you can take the back of the seat off to expose the pump and bladder
But unless you feel discomfort or have back problems it might not be worth the hassle.
Post #542265 Thu Nov 30 2017 7:00pm
