Home > General (L494) > Don’t forget........
Tim in Scotland
I woke up this morning to snow all round and -5c................... wipers are frozen to the screen as I didn’t put them to the winter park position last night........now where did I put the aerosol defrost spray last spring? 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
2015MY Corris Grey SDv6 HSE Dynamic, but not for much longer........
Post #541739 Fri Nov 24 2017 10:44am
Bill Portland
There's a winter park position? Merc C220 estate Sport AMG
Merc C220 estate Sport AMG 125 year edition
Alfa GT
Rover 76 V6
Post #541741 Fri Nov 24 2017 11:03am
timhum
The heated windscreen will soon free them. Winter tyres went on this week so ready for anything.
Tim
Post #541742 Fri Nov 24 2017 11:13am
Buckster
Re: Don’t forget........
Dont have that luxury Tim so just use my Remote FBH instead Wink 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection, LR Light Guards, 19"s on Goodyear Duratracs, ARB fridge, TuffTrek awning 😎
Post #541751 Fri Nov 24 2017 1:04pm
Tim in Scotland
Bill - In the dash menus
Tim - the blades park off the heated section of the screen in normal park mode 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #541752 Fri Nov 24 2017 1:05pm
Tim in Scotland
I don't have that luxury having bought a car that was intended for dealer stock in tropical London not Central Scotland, but come next winter I will have a car that will not only fit inside my garage but it will also preheat the cabin from the mains when the preheat timer is set thus saving petrol/ diesel and associated pollution (just shifting it to the local Hero-electric power station or wind farm!). In previous RRS's and FFRR's with cabin preheaters I could never get them to blow much warm (let alone hot) air from the vents after the timer had been activated, it was more of an engine pre-heater - anyway with the heated steering wheel and seats pre-warming the cabin wasn't really necessary. I found the Evoques system to be the best though - they have an electric cabin heater rather than using engine heat (same as many VW's) 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #541753 Fri Nov 24 2017 1:12pm
Bill Portland
My car must be missing some bits, I can't find a wiper park option nor, for that matter, can I disable the 20 minute wait to check oil levels on a recently stopped engine. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #541763 Fri Nov 24 2017 3:01pm
Tim in Scotland
I’ve just looked at your avatar and you have a 2012? The option is on L494 models not on L320’s,what you do need to do is to switch the auto-on to off for the wipers so the motor doesn’t get strained trying to drag frozen blades across the screen. On L494 you selectthe car set up menu and scroll down to the winter wiper park setting and switch it on, the wipers will make one sweep up the screen and then park higher up the screen than normal and on the heated section. 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #541767 Fri Nov 24 2017 4:33pm
