Home > Technical > Suspension erratic |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Might need calibration |
Thu Nov 23 2017 7:07pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Can you manually switch from off road height to normal driving height and from there down to access height?
Thu Nov 23 2017 9:11pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 867 |
Yes, you can select any mode with the switch & its fine, for example I had it selected at the lowest whilst washing it, but when I drive away it sometimes goes to top level (off road) instead of the normal mid level |
Thu Nov 23 2017 11:32pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8829 |
Sounds like it's thinking it's bottoming out. It then goes to off road height to allow clearing the obstacle. A calibration will probably solve it. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 23 2017 11:37pm |
