Home > Technical > Folding mirrors. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4755 |
The dam things work their way further and further down on tilt so best to turn that function off !
Mon Nov 20 2017 12:59pm |
There is an easy way to fix the driver’s door mirror - set the reverse dip position for that mirror to be the same as when driving forward then it won’t seem to dip...... I have always set mine up that way 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 20 2017 2:36pm |
Hey Tim....you mean when setting the memory settings yeah? Steve. |
Mon Nov 20 2017 2:53pm |
Select R, adjust both mirrors to your preferred settings, back to P or D, no need to press the memory button, that is for going forwards with different drivers using the car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 20 2017 3:14pm |
Ah yeah.....I got you Cheers. Steve. |
Mon Nov 20 2017 3:16pm |
Nope, that doesn`t work Any ideas? Steve. |
Fri Nov 24 2017 4:20pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
When I bought my 2005 RRS, the passenger mirror dipped whenever I selected reverse (which I found annoying).
Fri Nov 24 2017 5:49pm |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
Whenever I park and turn the engine off then lock the car, my driver mirror spazes out and points whatever way it wants to. I have to reset it everytime I get back in the car. Noisy black one |
Sat Nov 25 2017 11:58am |
Thanks, I`ll give that a go. Steve. |
Sat Nov 25 2017 1:38pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
What happens if you simply turn the dipping feature off completely in the settings menu on the stalk ?.
Sun Nov 26 2017 12:50am |
I assume they won`t dip! Steve. |
Sun Nov 26 2017 1:16pm |
No they won't dip, that's the object of the on or off setting, so what are you trying to do make the n/s dip and o/s remain stationary?
Sun Nov 26 2017 1:39pm |
Steve. |
Sun Nov 26 2017 2:11pm |
