Home > Maintenance & Modifications > Rear end vibration at high speeds and breaking
PC76
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
Evening all, had a run up to Scotland and back yesterday and at higher crushing speeds I noticed some vibration from the rear end. I think it’s the near side (left) also get strong vibration under breaking.
I initially thought wheel ballencing but might also have a separate issue due to the vibration under breaking. Also noted the two rear tyres wearing both outer edges of each tyre with the near side being worn slightly more.
Any ideas would be welcomed. Will hopefully be looking at it in the morning.
Post #540590 Sat Nov 11 2017 8:04pm
Paddi
Interpreting that literally - your tyres are underinflated.
Try them at 36 psi using an accurate pressure gauge.
If no improvement inspect the rear brakes including the EPB shoes and while you are in there check all the suspension components for wear. 2008 MY Java Black TDV8 HSE
Post #540640 Sun Nov 12 2017 10:48am
PC76
Hi Paddi,
I checked tyre pressures before I left as I had noted the wearing previously. All set to recommend pressures.. as for the accuracy of the gauge well I can’t vouch for that.
I don’t have a pry bar but inspected both rear ends for wear and all seemed ok.
I would normally suspect tyre ballencing for the high speed vibration and possible warped discs for the breaking... I may just bite the bullet and change the rear tyres for something decent as it currently has Sumita SUV Event tyres with a bucket load of weights on..... Rolling Eyes
Post #540641 Sun Nov 12 2017 11:02am
BKHK
Australia 2013 Range Rover Sport Supercharged Fuji White
Could be warped brake rotors. Could be wheels, tyres or rear diff. Don't know how long you have had the car? F80 M3 ZCP
2017 V8 SC - Gone after 11 months of ownership from new. Great engine surrounded by a cheaply made and unreliable car.
Post #540649 Sun Nov 12 2017 12:29pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Had it on mine brake callipers were seized.
Supporting the London Air Ambulance with my Brothers
Post #540650 Sun Nov 12 2017 12:47pm
PC76
Hi BKHK,
had the car from the 1st October
Panda,
Your suggestion covers all of the symptoms i am getting. Thx
Does anyone know if the callipers can be actuated using the IID tool?
Post #540663 Sun Nov 12 2017 4:34pm
Paddi
No they can't be actuated. The IID can put the EPB in service mode and has a facility to reset a jammed EPB (does not always work though) and to bleed the brakes. In addition of course it reads any brake related fault codes.
The brakes can be overhauled and adjusted without using. IID tool- see the great 'Bodsy's brake bible'
If you have one or more seized calipers they will be very hot after running so do a comparison by feeling the road wheels.
Vibration could also be a buckled wheel and by the sound of it your low budget tyres and poorly balanced rims will not be helping matters. 2008 MY Java Black TDV8 HSE
Post #540665 Sun Nov 12 2017 5:41pm
panda
They could be seized in the off ie not breaking. Wheels off to see if working.
Post #540673 Sun Nov 12 2017 7:29pm
