Home > Maintenance & Modifications > What is this loom for - and why would it not be connected
Meiang
I haven't driven my 2010 TDV8 since April this year and have decided to get it mobile again - the battery was dead.
I bought a new battery and pulled the old battery out and found the following, a disconnected major loom.
The second photograph is of the loom connected after I found the connectors separated.
What is this loom for and why was it disconnected.
The disconnection happened either at the factory or when the dealer replaced the battery under warranty about 3-4 years ago. No one else has even touched the battery since the car was new.
There is no way that I could have disconnected the loom by removing the battery.
Post #540547 Sat Nov 11 2017 7:59am
Disco_Mikey
Site Sponsor
Glow plugs... Confused MMP Land Rover - Land Rover + Range Rover Specialist
www.Facebook.com/MMPLandRover
Unit 9, 42 Baird Avenue
Dundee
DD2 3TN
Alive Tuning Authorised Dealer - Performance Tuning + EGR Deletes
Servicing + Repairs / Fault Diagnostics / EU3+EU4 EGR Blanking / Brakes Serviced/Replaced / Timing Belt + Oil Pump Replacement
Software Updates+Upgrades:
4x4 Info Enable / Sat Nav OTM / 3 Flash indicators / RRS Timed Climate Retrofit
Post #540554 Sat Nov 11 2017 11:27am
Meiang
So what would happen if the glow plugs did not operate? I have never had a problem starting the car even on a cool morning.
Post #540555 Sat Nov 11 2017 12:29pm
geoffsnook
depends on what you call cool Rolling with laughter
Post #540567 Sat Nov 11 2017 3:45pm
Meiang
At around 5-10 degress the cold start indication comes on for a second or so.
Post #540571 Sat Nov 11 2017 5:09pm
geoffsnook
Then the glow plugs will not work if they are not connected up so there fore a little slower/longer/harder to start i think Thumbs Up
Post #540572 Sat Nov 11 2017 5:21pm
