Home > Maintenance & Modifications > 2012 need Adblue
rjbrocklesby
England 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
2012 need Adblue
Sorry if this has been asked before but I'm guessing the 2012 model SDV6, 8 speed transmission doesn't use that Adblue stuff?
It's just that on the inside of the fuel filler cap there's a picture of what looks like something adding drops.
Ron 2012 SDV6 HSE LUXURY in Orkney grey.
Post #540474 Thu Nov 09 2017 8:41pm
Buckster
Definitely not Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection, Full Easy Lift Suspension Module, LR Light Guards, 19"s on Goodyear Duratracs, ARB fridge, TuffTrek awning 😎
Post #540475 Thu Nov 09 2017 8:46pm
rjbrocklesby
Thanks for that.
Don't suppose you know if the same model has the auto high beam?
Cheers 2012 SDV6 HSE LUXURY in Orkney grey.
Post #540476 Thu Nov 09 2017 8:48pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Should have, in the instrument menu you can select it. 2015 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #540484 Thu Nov 09 2017 10:05pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
rjbrocklesby wrote:
Thanks for that.
My car is a MY2012 and has auto high beam, here's a picture of the headlight switch selected to auto, check yours to see if you have the same.
Post #540487 Thu Nov 09 2017 10:19pm
rjbrocklesby
Mine does have an auto setting on the headlight switch so the lights come on and off when it gets dark. The high beam doesn't automatically come on though, so I presume there is a setting I need to do on the control panel as per Puslinch's post.
Post #540488 Thu Nov 09 2017 10:24pm
Johnski
The auto high beam on/ off is an option and not standard, the Auto on light switch is purely to turn on/off as required.
I think the label on fuel flap is also for you to check your oil level at stated mileage, and/or ad blue on later cars, wasn’t available in 2012 models you will be pleased to know. John
Post #540493 Thu Nov 09 2017 10:46pm
If you are referring to High Beam Assist, it can be turned on and off via the menu accessed through the R/H menu switch on the steering wheel Vehicle Set-up option, standard on A/B's option on other models. Should also be able to see sensor in interior mirror if I remember correctly. From outside off course. Laughing
Post #540495 Thu Nov 09 2017 10:49pm
