Home > General > Radio
J2D
Radio
Radio
Post #540190 Sun Nov 05 2017 9:07am
Simon B
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi there, Did you get any joy with this as my DAB has now got the same problem so I was wondering what you did to solve it.
Thanks Simon.
Post #543172 Mon Dec 11 2017 3:43pm
Tim in Scotland
I drove from Scotland to Fareham and back over the last 8 days and as soon as I got south of Carlisle my DAB stopped whereas on previous journies I have always carried DAB right through without even having to retune. Nowhere south of Carlisle could I get a DAB signal although FM was fine (since DAB came out I rarely use FM in the car but that worked fine on the journey) This afternoon I reset the tuner back to DAB and Radio 4 was back to it usual clear self back at home. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #543182 Mon Dec 11 2017 4:30pm
Simon B
I’m in Hampshire so perhaps it’s a problem in the south then.
Post #543185 Mon Dec 11 2017 5:24pm
J2D
All sorted
Post #545556 Thu Jan 11 2018 8:23pm
Tim in Scotland
I solved my issue by switching to FM for a couple of days and then reselecting DAB and set it to search again and it locked on straight away. Have you checked all your antenna connections on the rearmost windows and thatnone of the antenna wires bonded to the glass isn’t damaged? 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #545557 Thu Jan 11 2018 8:38pm
Simon B
Solved my problem, Plug came away from the DAB module, reconnected and hey presto everything is now all ok.
Post #545565 Thu Jan 11 2018 8:46pm
J2D
Where is the DAB module?
Post #545670 Fri Jan 12 2018 6:18pm
Simon B
No idea, Guy Salmon did it while they had the car for other things, didn’t charge me for that job though which was nice.
Post #545686 Fri Jan 12 2018 9:11pm
