Home > Technical > replacement engine |
Nige Member Since: 29 Oct 2017 Location: lancashire Posts: 82 |
back on the road in a bit
Fri Nov 03 2017 7:39pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Wow, that’s quite a lump! |
Sat Nov 04 2017 1:55pm |
yep,,getting the body off aint as easy as it looks BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 04 2017 4:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4320 |
Report back in 2 hours, with the body off |
Sat Nov 04 2017 5:14pm |
That looks like an EU4 engine, fitted with DR
Sat Nov 04 2017 5:17pm |
Sat Nov 04 2017 5:20pm |
In that case, it's not a straight swap...
Sat Nov 04 2017 5:27pm |
yep ,there is lots to do, could not believe how different the engines are,,i have two engines but the one pictured only has 50 thou on it BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 04 2017 5:32pm |
just a thought? when its all swapped over will it need coding ?????? BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 04 2017 5:34pm |
No |
Sat Nov 04 2017 7:09pm |
cheers mikey,will let you know how i go on,,BLOODY RANGE ROVERS i thought my discos were bad enough BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 04 2017 7:16pm |
They are just as bad. Done 3 last month |
Sat Nov 04 2017 7:20pm |
my old mans mate told me the 2.7 tdv6 was a french engine ( is that true? ) or was it a bit of northern pub banter BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Sat Nov 04 2017 8:29pm |
PSA collab, developed between Ford, Peugeot + Citroen |
Sat Nov 04 2017 10:02pm |
