Home > Technical > rear brake plates
Nige
rear brake plates
hi got the body off the sport for an engine swap,,had a good look around the chassis etc today,,bloody rear brake plates corroded to nothing,,is there a simple way to sort this or anyone had the same issue ? expensive item for a bit of steel Shocked BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
two discos v6 off contract (for sale) before they go to scrap
Post #540010 Thu Nov 02 2017 4:32pm
Paddi
The backplates support all the handbrake shoes and gubbins that are well known for seizing up and/or disintegrating and can b***er up the EPB module costing you many £££s
It may be a bit of a pain as you have to pull the hubs I think but change them; and while you are in there fit new shoes, springs etc and lubricate/adjust properly. Will be well worth it.
Have a good look at the brake lines from front to rear and over the rear axle - they are very well known corrosion area and so much easier to change body off. 2008 MY Java Black TDV8 HSE
Post #540014 Thu Nov 02 2017 5:10pm
Nige
thanks paddy,they are virtually disintegrated ,,another job to do,, BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540015 Thu Nov 02 2017 5:19pm
