Home > General > Tap Tap Tappity Tap
Pufftmw
Tap Tap Tappity Tap
Usually have the stereo on but was slowing down in between songs and I could hear a tap tap sound coming from the rear of the car. Turned stereo off and listened and sure it enough, tap tap tap which was clearly speed related coming from rear n/s of car. Once you were going fast enough, road noise turned it off. Slight squealing when braking at slow speed to stop.
Checked under car, nothing obvious hitting wheel, nothing hanging off, drive shaft did not move or appear loose. EPB works fine on steep hill.
Drove off and happened to go over a bit of frost damaged/bumpy road after which knocking/tapping stopped! Still a slight squeal from brake sometimes under gentle not firm braking.
Any ideas?
Post #539769 Tue Oct 31 2017 10:47am
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Tapping was probably a chunking stone trapped in your tyre tread.
Post #539771 Tue Oct 31 2017 10:51am
Paddi
Stone caught in the tread and/or between backplate and disc?
Inspect the tread and use your boyscout knife tool for removing stones from horse's hooves. Reverse at high speed to clear stone from backplate. 2008 MY Java Black TDV8 HSE
Post #539774 Tue Oct 31 2017 10:54am
Pufftmw
Hmm... Might have been. Tap did sound more mechanical than stone road noise though, it was a solid tap. I thought drive-shaft initially. I do have AT tyres and there are a lot of stones around here.
Post #539776 Tue Oct 31 2017 11:07am
not compressor then ?
Post #539780 Tue Oct 31 2017 12:01pm
Pufftmw
Does compressor make that noise? No errors on dash but I'll check IID
Drove it 10 miles with no sound/tapping then it came back again. Definitely not tyre/stone related.
Post #539793 Tue Oct 31 2017 1:34pm
Tim in Scotland
Have you been off-road lately? 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #539795 Tue Oct 31 2017 2:06pm
Rear prop shaft centre bearing? 2012 SDV6 - it's missing a couple of cylinders
Post #539796 Tue Oct 31 2017 2:09pm
Pufftmw
Pay n play a few weeks back and I had to go gently into a muddy field (low range, mud rut) on Saturday night to winch my tractor out again. Set everything back
Post #539798 Tue Oct 31 2017 2:52pm
Buckster
Could be that start of the EPB shoes getting filled up with crud! Sounds like similar symptoms to when my EPB failed. Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, 19"s on Goodyear Duratracs, ARB fridge, TuffTrek awning 😎
Post #539801 Tue Oct 31 2017 3:19pm
Pufftmw
Sound Clip
Made a quick sound clip of the noise with my iPhone stuck out the window going along slowly up a Welsh mountain road...
Sorry about the wind noise!
Post #539802 Tue Oct 31 2017 3:26pm
Tim in Scotland
Well from previous experience I think we can rule out the stone stuck in the tyre tread or something stuck in the dirt guard around the brakes. When I have had something stuck in the Defender’s dirt guard it has been more of a squeal than a ticking noise. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #539810 Tue Oct 31 2017 5:41pm
Pufftmw
Maybe a big stone hitting the inside of the wheel as it goes round? Though all the stones round here are pretty soft
Post #539858 Wed Nov 01 2017 9:42am
Socast
That's not a stone, have you checked the rear drive shafts for reeds or anything wrapped round them ?
If there's nothing there then check the props (front and rear as the sound could be travelling).
Other than that I would check that the driveshafts aren't worn or loose hub/s.
Post #539878 Wed Nov 01 2017 12:40pm
Pufftmw
Well...
Left the RRS for a few weeks then drove it round to my local garage. Tap-tap still going on but when took the owner out, it stopped again! Infuriating. Reversed the car and the sound came back. It did sound like the ABS system if its a ratchet type possibly? He's taken a look and "has ordered the parts" apparently & I'll find out exactly what it was next week.
Joys of a rural Welsh garage that specialises in (or otherwise sees a lot of) Land Rovers will be the hourly rate, so for once not too frightened about the bill I'll be getting (+service +MOT) Smile
Post #542923 Fri Dec 08 2017 3:07pm
