Home > In Car Electronics > Most loop
geoffsnook
Most loop
Hi am i correct in thinking that the head unit is the unit that actually sends out the red light of the most circuit Thumbs Up
Post #539533 Sat Oct 28 2017 2:14pm
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Yes, the head unit is the master Thumbs Up
Post #539535 Sat Oct 28 2017 3:14pm
geoffsnook
So i have no red light does this mean i have a head unit problem Crying or Very sad
Post #539536 Sat Oct 28 2017 3:17pm
GodivaNige
Have you been having other problems? Any DTC faults logged?
If there is no light output from the IHU then yeah, it’s not looking good for it. Try the usual suspects first, hard reset, MOST diagnostic screen
More info about the system http://media.disco3.co.uk/gallery/albums/u...ration.pdf
It’s a little generic, covering FFRR along with LR3 but the principles in this info are the same for RRS
Post #539539 Sat Oct 28 2017 3:28pm
geoffsnook
No other issues just swapped the wires on my D4 screen yesterday as had poor radio reception then noticed i had no red light now nothing no radio no sat nav nothing but everything else is ok Thumbs Up
Post #539542 Sat Oct 28 2017 3:40pm
geoffsnook
Crying or Very sad
Post #539595 Sun Oct 29 2017 1:33pm
geoffsnook
Would anyone know how to test the system when i dont have power to the head unit so cant turn it on to test the most ring Thumbs Up
Post #539599 Sun Oct 29 2017 2:32pm
geoffsnook
Does anyone know if there is a fuse inside the head unit as i have 12 volts going in but nothing works on the head unit or somewhere i can get it tested having read the pdf Godivanige Thumbs Up
Post #539663 Mon Oct 30 2017 8:36am
GodivaNige
I know my local indy has the equipment to test and repair problems with the MOST loop, but they're nowhere near you. Venture 4x4 in Warwickshire. They've sorted out a few RRS's and Discos in the past according to their FB page.
As for fuses within the head unit, no idea. I had loads of problems with mine doing very strange things, ended up buying a replacement head unit via eBay. Was very lucky in that I got a factory refurbished part that had never been fitted for £370 when they should be nearer £900. Came with a new fascia and new knobs, looked brand new and worked like a charm.
Post #539665 Mon Oct 30 2017 8:43am
geoffsnook
thanks have seen a few on the bay dont know weather to buy a cheapy to make sure it is that or to try and find someone who knows something about them and get it tested to confirm as i have power to the unit but nothing at all lights up or works and no light coming out of head unit
Post #539668 Mon Oct 30 2017 8:51am
scarey
this is from the FFRR's wiki page and might [or not] help you,
http://www.fullfatrr.com/gallery/albums/us...ration.pdf
Post #539678 Mon Oct 30 2017 10:25am
If you have 12v at the connector, and press the volume button knob the display should come on.
IIRC
no music, but display should be on.
black ground wire could be at fault
Post #539686 Mon Oct 30 2017 12:09pm
geoffsnook
Thanks everyone just checked continuity of fuses and 43 was knackered so result cheap fix Thumbs Up
Post #539687 Mon Oct 30 2017 12:09pm
