Home > Technical > Swap twin towing electrics for 13-pin?
confuzed
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Hi,
I'll be picking up my 2013 RRS HSE Black Edition next wednesday (just a bit excited) - it currently has twin towing electrics fitted, and includes the Land Rover removable tow bar.
Has anyone tried swapping the type of electrics fitted? I'd ideally like to swap this to euro-style 13-pin electrics. Would this require "coding", or is towing electrics just an on/off as far as coding goes?
Thanks for any advice
Post #539265 Thu Oct 26 2017 12:51pm
Jaggs
Sure there will be away to change it, I just bought a plug in convertor so I have the option of towing on old or new style electrics Nanocom Evo
Post #539275 Thu Oct 26 2017 1:37pm
confuzed
Thanks Jaggs - I'll be using a plug-in adaptor for now, I just thought I'd investigate the swap as an option since virtually all of my towing will be with 13-pin for my caravan
Post #539278 Thu Oct 26 2017 1:51pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
you want the 13 pin if your caravan has the anti sway fitted so it will work Wink Wink
Andy. 2014 RRS SC santorino,coris roof.
2016 VW Amarok Highline,candy white
2014 Evoque D-Lux Fuji
Previous motor.
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #539280 Thu Oct 26 2017 2:12pm
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I bought a 13 pin kit from Dan @ Duckworths. I didn’t realise my car had the 12n&s electrics already fitted (I put a deposit on the car, and knowing I was going to be using it for towing I ordered the electrics before I actually had the car) All I did was change the lower half of the loom, and it all works fine!
Post #539283 Thu Oct 26 2017 2:17pm
confuzed
Assuming you're referring to the Alko ATC system? I did some searching on here and found reference to others who have working ATC from the twin-electrics (but not single due to the lack of permanent live); so I think I'm ok on that front. Of course, I can easily test this in the drive before I actually tow anywhere - I'll try to remember to post back here to confirm one way or the other.
Post #539315 Thu Oct 26 2017 3:11pm
confuzed
Thank you PhilMid, that's ideal. I'll check the cost and check whether the ATC works on the twins before I decide to do anything, but its good to know I have the option.
Post #539316 Thu Oct 26 2017 3:14pm
Tyrefitter
When I had my RRS1 2012 I had 7 pin electrics fitted but when I got the caravan (my friend who owns a Towbar company) fitted 13 pin electrics for the atc system to work.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #539362 Thu Oct 26 2017 6:26pm
riverblanche
Hi,
The ATC works off the “S” plug so needs to have the twin 7 pin plugs fitted 👍 Corris HSE Dynamic 2016
Always pick up stick in the middle !!
Post #539396 Thu Oct 26 2017 11:18pm
