Home > In Car Electronics > Clock on dash disappeared |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Not sure if it will work and I am no expert but I have just bought a IID BT tool to add clock to dash and noticed that it only sets at 00:00 so maybe worth disconnecting the battery tonight just before midnight for a few minutes and reconnecting it to see if the clock sets the time.
Fri Oct 20 2017 7:08pm |
I just found this on the Gap Diagnostic IID tool manual. Seems like it might need a reset with the tool;
Fri Oct 20 2017 10:13pm |
Tom55 Member Since: 24 Mar 2017 Location: Wolverhampton Posts: 27 |
I’ll give it a try tomorrow, thanks very much for the info mate |
Fri Oct 20 2017 10:24pm |
When you set the clock on the radio it also sets the clock on the dash |
Sat Oct 21 2017 1:45pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
had the same problem after i had the clock done by Bodsy it disappeared due to me false starting the car, all i had to do was reset the ecu |
Sun Oct 22 2017 2:37pm |
Nicard Member Since: 24 Nov 2015 Location: Fife Posts: 29 |
had the same fault, reset the ecu and this solve it for me. |
Sun Oct 22 2017 6:56pm |
It can happen when the battery is low. The ecu gets drained of power and they start up in the ‘wrong’ order. The instrument pack syncs to the radio for the time and it misses that signal order.
Tue Oct 24 2017 8:31am |
Thanks all sorted now |
Thu Nov 09 2017 8:05am |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Is it possible to set the clock time with IID tool ?
Fri Mar 16 2018 10:39pm |
