Home > Maintenance & Modifications > Powering Equipment with Ignition Off
garrycol
Australia
Is there a simple way to disable the need to have ignition on to move windows and seats etc.
When you turn the ignition off power windows and seats still work until the car goes to sleep then nothing works. Has caused a few problems with people in the car when I walk off with the keys - they cannot open or close windows or adjust seats.
Obviously I can play around with wiring so they are live all the time but that is a lot of mucking around - does anyone know another way to disable this annoying feature.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #538671 Thu Oct 19 2017 4:12am
Bodsy
Site Sponsor
Nope. Do they really need to be messing with seats once they’re in and comfortable? As for window opening, if it gets too hot, open the door.....
Or leave them with your keys.... Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #538691 Thu Oct 19 2017 1:18pm
annoying.
Other older cars of different makes (ford/vauxhall) used to enable the windows when the drivers door was open.
It would be so easy these days to implement when car designed.
Post #538709 Thu Oct 19 2017 4:40pm
Lucifus
United Kingdom 2009 Range Rover Sport TDV6 S Java Black
How long is the timer after the ignition is switched off?
Post #538712 Thu Oct 19 2017 4:52pm
RallyXS
If it goes off can't you press the power on button. It won't start obviously, but I thought it still turned things on such as windows. 2012 RRS SDV6
2014 BMW 320d X-Drive Touring
1999 VW Polo stage rally car
Post #538740 Thu Oct 19 2017 9:50pm
Not a key less model.
Don't you need the fob present anyway?
Post #538743 Thu Oct 19 2017 9:55pm
Johnski
Yes Andy. Thumbs Up
Not sure on earlier model OP has though, but your model Andy is around the same year. John
Post #538752 Thu Oct 19 2017 10:35pm
garrycol
Australia
I take that is a no then - stupid arrangement.
I am sorry but some of my passengers have complained about getting hot when I have gone away from the car with the keys - they want to open the windows (or be able to close them in a dodgy neighbourhood) - opening the door is a often not an option or a poor option to poor design when you should be able to simply lower the window.
Oh well. Sad 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #538757 Fri Oct 20 2017 1:49am
Perhaps it's all part pf the "Stupid" anti-trap feature which stops kid's or even animals if left in the car alone for whatever reason with the window partly open strangling themselves by accidentally closing the window when their head is stuck outside, or possibly opening the window and falling out splitting their head open on the concrete, tarmac or whatever. I think the actual "anti-trap" feature is actually a legal requirement now.
Post #538758 Fri Oct 20 2017 4:53am
a work around is to open the wind a center-meter before switching off.
I know its not great
Post #538819 Fri Oct 20 2017 7:35pm
