Home > Technical > ECU location
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
ECU location
could someone please the me were the main ECU is on my 2008 rrs Sad
Post #538640 Wed Oct 18 2017 8:02pm
It's between the battery and the cabin firewall. You need to remove the battery to access the ECU box. The box includes the transfer box control module. 2012 SDV6 - it's missing a couple of cylinders
Post #538643 Wed Oct 18 2017 8:07pm
Johnski
Not sure for that year, but following should find it.
It should be under the bonnet in engine compartment at the back, where brake fluid reservoir is for checking and filling. You have to remove the black plastic type cover off by by windscreen, removing the four screws/clips depending on model.
Generally drivers Side, although I believe it can be on either side just for added confusion. Sorry, hope that slightly helps.
EDIT. Typed reply to slow, Well done RRST. Embarassed John
Post #538644 Wed Oct 18 2017 8:12pm
On Battery left side.
Assuming you want engine Ecu
Post #538650 Wed Oct 18 2017 8:24pm
Johnski
Just found this photo install/removal guide on web.
http://www.fabspeed.com/templates/__custom...0Guide.pdf John
Post #538652 Wed Oct 18 2017 8:29pm
blueiceplus
Thanks alot, so I'll just put this one back under the drivers seat Sad
Post #538654 Wed Oct 18 2017 8:33pm
Johnski
One under drivers seat is normally the amplifier for the Harman Kardon stereo system. John
Post #538655 Wed Oct 18 2017 8:35pm
I think the BCM lives under the driver's seat too. 2012 SDV6 - it's missing a couple of cylinders
Post #538665 Wed Oct 18 2017 10:06pm
Memory module under seat too.
Bcm by glovebox fuse box
Post #538666 Wed Oct 18 2017 10:08pm
