![]() | Home > Technical > power steering problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 1788 ![]() ![]() ![]() |
No. |
there a post on D3 where by the steering column is lubricated at the side of the engine.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 370 ![]() ![]() ![]() |
I had a similar issue on my last rrs. Eventually it got worse, then resulted in excess play.
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 87 ![]() ![]() |
i did a lot of driving today, it seems to start getting a bit stiff after a few hours, when i turned the engine of for about an hour it was fine till about a couple of hours driving it started to give stiff again |
Must be the heat from the engine near the joint. |
