Home > General > Run off rubber seal on front window help
Tizzard
Hi all the rubber seal that lets the water run off at the bottom of the front window on my 07 plate sport has decided to lift up in a certain place and I don't no what to use to stick it back down. I tried cilicone but only lasted for a couple of days. Has anyone else had this problem and how have you fixed this and by using what?
You can see in the pictures below
Post #538449 Mon Oct 16 2017 3:42pm
PEACHY
TBH - don't think it will cause any permanent damage - I have replaced 2 of those due to fading & they are not sealed to the windscreen. It's about 30 mins to change & is a DIY job Thumbs Up For about £50 you can purchase a new one - someone on here will identify the part number - all my paperwork - receipts went with the sold Sports.
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #538460 Mon Oct 16 2017 6:06pm
PEACHY
Just found this Very Happy
http://www.rrsport.co.uk/gallery/albums/us...hamber.pdf
Part number JAG500012 Thumbs Up 16MY Estoril Blue SVR.............
Post #538461 Mon Oct 16 2017 6:09pm
Tizzard
Thanks for that. Will the water cause any damage to anything by running under it instead of over it and any idea where to pick a new one up from?
Thanks wayne Thumbs Up
Post #538464 Mon Oct 16 2017 6:42pm
PEACHY
I got mine from Site sponsor Dan @ Duckworths - there is a few on the well know auction site Whistle all used but seem in good nick Wink
Some water must get through even on the new ones & if I'm honest I can't remember what was underneath. I'd change just to be sure - if you do buy used if you can make sure it comes with clips - also use a good plastic restorer on it before installation. 16MY Estoril Blue SVR.............
Post #538465 Mon Oct 16 2017 6:48pm
Tizzard
Has anyone got any links or could tell me where I can buy a new scuttle panel for my car Thumbs Up
Post #538500 Tue Oct 17 2017 9:47am
Paddi
Best bet is to ring/email Dan at Duckworths: here's copy of his email signature below.
IIRC the panel is about £50 and comes with the clips. Be careful fitting it as the plastic is really brittle and easily cracked.
Dan Roberts
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
 2008 MY Java Black TDV8 HSE
Post #538505 Tue Oct 17 2017 10:47am
