Home > Technical > Help ecu has triggered pump solonoid to close.
Ste815l
Was driving and car said engine system fault I pulled over then it cut out.got it home checked for fuel pressure and isn't any. Assumed pump failed got new pump and solonoid and it primes but no fuel comes past the solonoid. My old pump actually works so this wasn't the problem. I've tried disconnecting the battery still not working. Any help on how to reset it or can the solonoid be gutted or bypassed thanks.
Post #538297 Sun Oct 15 2017 8:43am
Ste815l
Fixed
Post #538396 Mon Oct 16 2017 8:26am
geoffsnook
well done please share the fix with us Thumbs Up
Post #538398 Mon Oct 16 2017 8:29am
Ste815l
The solonoid takes a negative draw to produce a magnetic charge to open the plunger. I had a poor earth connection causing it to open and close when I went over speed bumps ect. New earth cable and hopefully fine.
Post #538434 Mon Oct 16 2017 1:21pm
geoffsnook
Post #538440 Mon Oct 16 2017 2:23pm
