Home > Technical > Headlights |
grhspenny Member Since: 02 Oct 2015 Location: Durham Posts: 9 |
Hello all.
Fri Oct 13 2017 3:01pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Is it the auxiliary fill-in beam or the Xenon that is staying on? Or both? If it's the Xenon then it might be the shutter that is stuck. Might be possible to free it off in that case. 2012 SDV6 - it's missing a couple of cylinders
Fri Oct 13 2017 7:29pm |
Hi. Not sure about what light unit is which. Its the single bulb unit.
Fri Oct 13 2017 9:16pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Trouble is the flap will be powered. Hope it doesn't flatten battery. |
Fri Oct 13 2017 9:38pm |
Sure enough when I went out in the dark and tested despite removing the bulb the flap must be powered and that bulb is on high beam but at least only when the lights are turned on |
Sat Oct 14 2017 12:46am |
So far no solution but no flat battery. |
Sun Oct 15 2017 9:51am |
I think you had your solution in the second post.
Sun Oct 15 2017 10:11am |
