Home > Maintenance & Modifications > Thinkware F770 Voltage Setting |
Hi guys. A bit of advice please from those of you with this Thinkware dashcam. What voltage have you set for it to shut down to prevent battery drain. I've got mine on 12 volts currently but that means it doesn't stay on long in park recording mode before turning off. Wonder how low I could set it but still leave enough power (with a margin) to start the car. Robin
Fri Oct 06 2017 2:40pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2006 |
I might get one of these and tuck it under the passengers seat. I currently power my dashcam with a long lead routed to rear seats 12V socket.....
Fri Oct 06 2017 3:48pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
I used to run myself be on 11.8 and the next down 11.6? And never had a issue with starting |
Fri Oct 06 2017 3:50pm |
That looks a really good option - but at a price. I'll take a chance on the npinks route at least initially and try a lower voltage setting to see how that goes (flat battery, here I come... ) Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri Oct 06 2017 4:33pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5584 |
When I had the RRS I had a Blackvue and had to set it on lowest voltage or it would switch off in winter with heated seats etc on
Fri Oct 06 2017 9:17pm |
