Home > General > RRS V Discovery3 |
I would say having moved from a disco 3 to a RRS that it feels a bit smaller and mine is a bit lower on the drivers seat but mine is the supercharged but it is every bit as comfortable probably a lot more |
Thu Oct 05 2017 3:33pm |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 |
Hello Murphy,
Fri Oct 06 2017 3:32pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 405 |
RRS 2006:
Fri Oct 06 2017 3:56pm |
Sorry, but I have found other values for the Discovery:
Fri Oct 06 2017 4:07pm |
Did not say the supercharged was actually lower than a normal range rover sport but did say feels smaller and lower |
Fri Oct 06 2017 4:15pm |
Sorry Geoffsnook, I misunderstood you. |
Fri Oct 06 2017 4:25pm |
Fri Oct 06 2017 4:31pm |
No apologies needed here - just copied and pasted from LR websites. Barrie.
Fri Oct 06 2017 4:42pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
the suspension height calibrations are slightly different on the RRS v D3 |
Fri Oct 06 2017 5:31pm |
murphy Member Since: 04 Sep 2017 Location: London Posts: 22 |
Thank you all for the reply's
Sat Oct 07 2017 7:46am |
It can't be 10 inches wider. It's not possible! |
Sat Oct 07 2017 9:59am |
I think that the difference is actually because some measurements are including mirrors, and some without. |
Sat Oct 07 2017 10:06am |
Yes nebc100, that is probably the reason |
Sat Oct 07 2017 10:14am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
The difference in width is minimal - inside width is basically the same. The RRS is shorter because the wheelbase is shorter. The drivers sear sits basically the same in both cars - differences are in adjustments available in different trim levels. My seat is adjustable up and down as are some D3 seats. Driving position is the same but feels different because of the upright nature of the D3 dash. 07MY RRS TDV6
Sat Oct 07 2017 11:02am |
