Home > Technical > Range rover supercharged |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Yes, you can turn it off at the steering wheel, but it disengages the cruise control completely it does not revert it to manual operation. If yours does for some reason it's a bonus
Fri Oct 06 2017 2:26am |
I really like ACC but you have to remember what its designed for. Its a motorway cruising aid and not really something for A roads for the reasons others have stated cos it pick up random other things and slams on the brakes. (But yes, I do use it on some A roads and in town to make sure I don't exceed the speed limit cos I'm a good boy ).
Fri Oct 06 2017 7:39am |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Yeah you're right about it being purely a motorway cruising aid. It works well enough for that. Just a shame it can be a liability using it on A/B roads. Toggling between ACC and CC seems like an obvious thing you'd want to do. |
Fri Oct 06 2017 7:46am |
I've never used it myself (properly) but there is a button near the hazards that turns off/on forward alert (not the button for the parking sensors), This may well disable the radar on the ACC. |
Fri Oct 06 2017 11:01am |
Aha! So Socast, it appears that there are variations in design. Well who'd-a-thought it?
Fri Oct 06 2017 3:15pm |
Oooooooo....that`s what that button does ACC off for me then Steve. |
Fri Oct 06 2017 4:10pm |
I think i will give that a go as well |
Fri Oct 06 2017 4:18pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
How odd, my MY08 TDV8 (late 2007) has that button |
Fri Oct 06 2017 4:25pm |
I want more buttons Robin
Fri Oct 06 2017 4:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
http://www.ebay.co.uk/itm/Landrover-Range-...SwAyBZnvlP
Fri Oct 06 2017 5:07pm |
Robin
Fri Oct 06 2017 5:16pm |
Just tried my button in a 30 mph did not make any difference still had auto braking |
Fri Oct 06 2017 5:18pm |
I may well be interpreting the Handbook wrong, but It say forward alert is active when switched on and ACC is off. It gives you the same warning as ACC without the braking aspect, it makes no mention of it turning off the Automatic side and reverting to Manual control of the Cruise Control i.e. set speed with no braking effect. If I remember correctly I always had it turned off in my old sport because I found the permanent green icon illumination in the instrument panel annoying when turned on. It made absolutely no difference to the ACC operation itself.
Fri Oct 06 2017 5:48pm |
Balls Steve. |
Fri Oct 06 2017 6:35pm |
