Home > Technical > Headlight still not raising after replacement
Flatteraxe
United Kingdom 2007 Range Rover Sport TDV8 HST Java Black
I have an 07 TDV8. I had an issue with the drivers side headlight not raising properly, I have bought a replacement unit and the problem is still there.
There is a lever inside the headlight, I have tried to play with this but it doesn't really do anything. I think this lever just alters the beam pattern for driving in Europe.
After having the headlight out it looks like the beam pattern is slightly higher but as soon as I drive it the beam drops again.
What can I do now?
Post #537335 Wed Oct 04 2017 6:51pm
Paddi
Have you already had the modules scanned for fault codes? If not, do that next.
IIRC there is a module that controls the AFS; it may be faulty or the wiring maybe at fault? 2008 MY Java Black TDV8 HSE
Post #537339 Wed Oct 04 2017 7:31pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
You're right in that the lever does simply deflect the beam for Euro' driving. Sorry but I don't have the knowledge to help resolve your problem. Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #537348 Wed Oct 04 2017 8:09pm
Eaters
You might want to check out this post.
http://www.rrsport.co.uk/forum/topic45088.html
Not sure if this is the same problem as yours but it may help Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #537362 Wed Oct 04 2017 9:28pm
