Home > In Car Electronics > Head unit and nav
Page 1 of 3 123>
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Head unit and nav
Sorry if already covered
My head unit has started playing up
The unit powers up but no sound I can change from radio to disc but nothing else
When I turn volume up not getting volume setting display on screen
Also nav stays on Land Rover screen
Then all of a sudden it starts working
Has anyone got any info on this problem
Thanks
Cosmo
Post #537161 Tue Oct 03 2017 7:52pm
Not unknown.
Do a search
Post #537166 Tue Oct 03 2017 8:24pm
Cosmo15555
I have just checked faults and this was in system
U1A03-62 (6Cool Vehicle configuration parameter - Algorithm based failure - signal compare failure
Hope this helps if anyone knows the problem
I tried the pushing tuning knob to reset radio but nothing happened
I then tried changing car configuration with iid tool which resets car but still no change
Post #537183 Tue Oct 03 2017 9:11pm
geoffsnook
Sounds like you have messed up the ccf if you go into the IDD tool and find the save/restore part and restore the original file that was saved when you first plugged it in it should return the car to its original state or your amp.most circuit may have a fault Thumbs Up Thumbs Up
Post #537211 Wed Oct 04 2017 7:10am
Cosmo15555
The stereo was doing this before I connected the iid tool in but thanks for the suggestion
Post #537215 Wed Oct 04 2017 7:55am
geoffsnook
Sounds like maybe the amp or can you do i hard reset first as it’s simple it is explained in the wiki Thumbs Up
Post #537216 Wed Oct 04 2017 8:00am
d-9
Start off by disconnecting the battery for 10s or so. Mine used to do that until I replaced the battery. Sat nav screen would freeze on the LR logo too.
Post #537243 Wed Oct 04 2017 10:07am
Cosmo15555
I tried disconnecting the battery but didn’t sort out problem then I disconnected the battery an joined the cables together with jump lead then reconnected live then earth but still the same
Tomorrow I will check the connections into amp
I’ve read some posts listing water ingress causing problems does this happen to the amp
Post #537358 Wed Oct 04 2017 9:08pm
Cosmo15555
I spoke to a car audio Center today they said could be amp or even Bluetooth module
Not sure if related last week I tried used some cloths I keep in cubby hole where Bluetooth module is and the cloth was quite wet
Do the sports have problems with water getting in around this area and could this be the cause of my problem ie water has got into Bluetooth module
Post #537454 Thu Oct 05 2017 4:57pm
I guess their concern is that the optical network is broken, so the sound doesn't get to the amp.
They have a good point.
Is the bluetooth talking to the headunit ok ?
Post #537457 Thu Oct 05 2017 5:02pm
Cosmo15555
I’ve tried 2 different phones that are paired with the module but neither will connect with it
Post #537475 Thu Oct 05 2017 7:26pm
You can get an optical loop off for a couple of quid to disconnect the Bluetooth And see if sound is restored
Post #537484 Thu Oct 05 2017 8:31pm
Cosmo15555
Thanks for reply 👍
Post #537491 Thu Oct 05 2017 8:52pm
scarey
this is for the L322 but the same applys to yours,
http://www.fullfatrr.com/forum/topic24270.html
Post #537511 Fri Oct 06 2017 7:35am
So the FF owners use a Biro Laughing
Post #537538 Fri Oct 06 2017 2:34pm
Page 1 of 3 123>
