Home > Maintenance & Modifications > Rusty Wheel Nuts |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
Hi everyone,
Tue Oct 03 2017 4:53pm |
Looks much better Steve. |
Tue Oct 03 2017 5:43pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
Recently Had the swollen nuts issue When I took it in for a service they said I had 9 swollen nuts since replacing I have noticed a slight wheel vibration I had has now disappeared completely which has saved a trip to my tyre guy
Tue Oct 03 2017 6:21pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
See this thread for swollen nuts
Tue Oct 03 2017 6:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
No reason not to put small amount on threads, have been doing it for year's on all sorts of vehicles and never had any issues with loose wheels or seized/corroded nut's. I always use a torque wrench though. Cheers Col |
Tue Oct 03 2017 9:54pm |
I seem to have stirred up a discussion on the use of copper grease, which was not my intention!
Tue Oct 03 2017 11:06pm |
Do you adjust your torque setting for wet thread, the book value is probably for a clean dry thread... 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Oct 04 2017 4:35am |
Nope, as L/R don't specify lubricated or not just torque them up to required torque and that's it, as I said never had a issue it 35+ years so happy with that, although admittedly I believe there is a formula to calculate variations but you need to know whether the bolts/nut's are plated i.e Zinc, Phosphate, Cadmium etc. as well.
Wed Oct 04 2017 5:58am |
I used to have a copy of a chart listing all the torque value adjustments, but will admit I also never use it (no idea where it is now either). From memory it went as far as different lubrication value's in oils, like thin oil, thick oil, grease etc. I was hoping the little devil after it might hint at a bit of sarcasm...
Wed Oct 04 2017 7:33am |
Yeah did actually guess that, never really worded my response very well, bit to serious at times these days might well be a age thing.
Wed Oct 04 2017 7:43am |
