Home > General > Whip crack away |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Make sure you get a good one - lots of threads on here. Do a search Visitor from fullfatrr.com
Tue Oct 03 2017 6:33pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
So I had the windscreen fitted, but today I noticed the passengers carpet is wet, so straight on the phone. A chap from the same company but the Salisbury branch had a look. The windscreen is water tight but the trim wasn't fitted right which let water in through the cabin filter and into the car, the filter was soaked. So I've complained waiting a reply.
Mon Oct 23 2017 8:48pm |
And if I remember rightly one key check, if possible in the current warm climate, is to check the heated front screen is working properly Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Tue Oct 24 2017 12:06am |
