Home > Technical > EPB stuck and has been released. Can you stop flashing light |
The epb should be used even though it`s auto...I`ve been told if it`s not it can cause issues. Sorry I haven`t answered your question...just passing on some knowledge as I currently have an issue too Steve. |
Sat Sep 30 2017 1:19pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
If parked on a slope then yes, use the EPB as the park lock pawl within the gearbox isn’t designed to hold the weight of the car. On level ground it’s ok to leave the EPB off and put the gearbox in Park
Sat Sep 30 2017 1:44pm |
That`s different to what I was told. Hey ho. Steve. |
Sat Sep 30 2017 3:15pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
The light is flashing as there is a fault in the system. Repair the fault, light goes out |
Sat Sep 30 2017 7:46pm |
Itaylort Member Since: 30 Sep 2017 Location: Pembrokshire Posts: 14 |
Thanks for the responses. Today we stripped down to look at the shoes. All looks ok and readjusted as per Bodsy’s bible. Still have the screech.
Sun Oct 01 2017 1:36pm |
Just to close the loop on this one.
Sun Oct 08 2017 7:46pm |
I believe disco 3 and the sport use exactly the same brake system but i am wrong a lot |
Sun Oct 08 2017 8:24pm |
I was really thinking about orientation and ease of access might be a lot easier on a disco than a rrs |
Tue Oct 17 2017 6:48pm |
