Home > General > Fuel Burning Heaters - Standard?? |
Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 208 |
Going to view a facelift 2009 3.0 TDV6 HSE tomorrow and with the exception of a sunroof it seems to be fully loaded, however I am quite keen to establish if it is fitted with a FBH as standard and where I should look to physically confirm its presence?
Thu Sep 28 2017 8:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
Yeah standard.
Thu Sep 28 2017 8:22pm |
Oh ok that's useful to know it's standard fit, is it not configurable on a timer via the onboard settings? I don't want to have a remote to switch it on, just looking to say set it for 5am and know that when I go out at 5.30 it's been on half hour, cabin is warm and glass defrosted - can I do that?
Thu Sep 28 2017 9:00pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Generally when fitted they are not timed or controlled by RCU as that is an extra, (Could have been done by previous owner or some trims and option packs include it) but it will automatically turn on when temperatures are low enough to turn on when you start up and drive.
Thu Sep 28 2017 10:23pm |
Thanks Johnski, that's really helpful - so the basic system then, does it just increase the speed at which everything warms up on a cold day then if it doesn't kick in until the car is started?
Fri Sep 29 2017 6:59am |
That's correct Sit.
Fri Sep 29 2017 10:50am |
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 |
If you only want the timer you don't need any equipment, I got mine activated at a local independent who plugged in his machine. 2012 RRS SDV6
Fri Sep 29 2017 6:47pm |
It is model year dependant, and most will find pre facelift L320 can't. Many didn't even have FBH. John
Fri Sep 29 2017 7:46pm |
