Home > General > side steps |
murphy Member Since: 04 Sep 2017 Location: London Posts: 22 |
Hi. I have been looking at side steps for my RRS found these on ebay are they any good or are they rubbish, has anyone any advice http://www.ebay.co.uk/itm/New-OEM-Spec-Sid...rksid=p206 |
Thu Sep 28 2017 2:12pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Can't comment on that model which is very cheap around £500+ less than genuine.
Thu Sep 28 2017 2:19pm |
Thank you Johnski, and Tyrefitter do you mean the ones I linked to have the plastic covers, I don't mind spending a a bit more if you could tell me which ones as I do not know very much about them |
Thu Sep 28 2017 2:50pm |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Hi Murphy,,the ones you have linked have the plastic sill covers pre-cut which are easy to fit,,you can buy some without them & cut your own but its a nightmare marking them out & it takes 3 times aslong to fit.
Thu Sep 28 2017 2:54pm |
Thank's Andy
Thu Sep 28 2017 3:32pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
Thanks everyone for the info.
Fri Sep 29 2017 10:30am |
Please if you could post about quality/finish etc once fitted so this can be passed onto others when asked in future.
Fri Sep 29 2017 2:03pm |
m3virus Member Since: 18 Sep 2013 Location: birmingham Posts: 36 |
I bought a set of steps from them guys quality finish is great look identical to genuine,
Fri Sep 29 2017 2:37pm |
I bought a set off eBay for around the £160 mark. Easy to fit and good enough for me
Fri Sep 29 2017 11:01pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
When I did mine I actually changed the bolts for stainless steel one's as well as copper slip. Cheers Col |
Fri Sep 29 2017 11:07pm |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
I purchased a set of side steps off eBay and I was very pleased with the quality. Fitting is a relatively easy DIY job just put the suspension to its highest setting and there is enough ground clearance to fit the steps without jacking up the car. I too put plenty of grease on the bolts and some corrosion protection on the brackets.
Mon Oct 02 2017 11:06pm |
Ive just ordered a set for mine £137.50 by the time Ive claimed the dreaded vat back,,I’ll let you know how the quality is & how easy to fit as I’ll be fitting them probably Friday..But I have got ramps & lift to make it easier.
Tue Oct 03 2017 6:35am |
Best of luck for Friday Andy.
Tue Oct 03 2017 8:31am |
Ive got some Gtechiq C5 left over so I might just put some on the alloy part of them.
Tue Oct 03 2017 8:46am |
