Home > Technical > Rear Suspension Settling |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
There are lots of threads on settling suspension - mine is settling at the rear - equally on both sides - air leak or valve block.
Fri Sep 15 2017 1:56am |
Thanks - nothing on the suspension system has been touched or serviced in its life so I may have to have a look at that.
Fri Sep 15 2017 2:13pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
I would pull the EAS fuse and see whether it still drops. For not, it's something electronic. If it does still drop them it's a leak. 2012 SDV6 - it's missing a couple of cylinders
Sat Sep 16 2017 9:42am |
Thanks for the information - is that fuse an engine bay or cabin fuse?
Sat Sep 16 2017 1:10pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Engine bay.
Sat Sep 16 2017 1:40pm |
Thanks I will find it.
Sun Sep 17 2017 3:15am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 406 |
garrycol - Out of interest, when you park up overnight are you on flat ground or on a gradient? Barrie.
Sun Sep 17 2017 7:06am |
Is normally parked in my garage so on flat ground. 07MY RRS TDV6
Sun Sep 17 2017 1:09pm |
