Home > Maintenance & Modifications > Parts and oil recommendations |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
Get the Timken OEM front bearing. Don't bother with the cheap stuff or you'll be changing it again in months if you do. Make sure you use the new, lower, torque figure for the hub nut (230Nm I believe but others will confirm).
Tue Sep 12 2017 10:47pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Use genuine LR oil for transfer box.
Tue Sep 12 2017 10:51pm |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 |
As RRSTDV8 says
Tue Sep 12 2017 11:03pm |
