Home > Maintenance & Modifications > 2006 rrs se faults. 2.7 diesel |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4780 |
Charge the battery |
Fri Sep 08 2017 7:38pm |
Donegalrangerover Member Since: 05 Sep 2017 Location: Donegal Posts: 8 |
Hi Andy,
Fri Sep 08 2017 7:41pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
They haven't steam cleaned or jet washed the engine during the valeting have they? |
Fri Sep 08 2017 10:32pm |
Hi,
Fri Sep 08 2017 10:43pm |
If it were my car, bearing in mind it was fine before valeting, I would check for water ingress under the bonnet. That would mean disconnecting every electrical connection I can find, drying it, applying wd40 or similar and seeing if that makes any difference. Have you had faults read yet? |
Fri Sep 08 2017 11:12pm |
there are some ecu's behind the battery that don't like getting wet.
Sat Sep 09 2017 10:20am |
Update from today. Had it on the computer and theres no communication with the transmission control module.
Sat Sep 09 2017 8:55pm |
This thread may be of help to you:-
Sat Sep 09 2017 9:11pm |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 |
As someone mentioned above there are ecus behind the battery and I'm sure the transmission ecu is one of them. Clickadeeclick |
Sat Sep 09 2017 9:32pm |
Thank you everyone for your assistance.
Sun Sep 10 2017 6:46pm |
You have been lucky
Sun Sep 10 2017 6:56pm |
Glad you are sorted, enjoy the car now. |
Sun Sep 10 2017 8:41pm |
