Home > Maintenance & Modifications > Range Rover sport 2010 suspension |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Sun Sep 03 2017 6:46pm |
rangeroverloon Member Since: 20 Aug 2017 Location: leatherhead Posts: 9 |
I had all the height sensors calibrated by Land Rover and they said they were all functioning as it should. I cured the problem of extended mode by either changing the 2 shocks or cleaning out the cross over valves. I just don't get why it's is so different in access mode |
Sun Sep 03 2017 6:53pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
The calibration wasn't done correctly, it seems, or you need a new sensor. The vehicle goes in to extended mode when you select access height because it gets to the bottom of the available suspension travel before the system thinks it should. This registers as it grounding out on something. In order to protect the vehicle it then raises the car to allow you drive away from the "obstacle".
Sun Sep 03 2017 10:02pm |
Thanks for the replies. I took it to Land Rover as my local specialist couldn't calibrate it. When it's in standard height it seems to be fairly level. I only get this problem when it's in access mode. The suspension doesn't go into extended mode anymore anymore as I'm think I have cured that by changing the passenger side shocks or cleaning out the valves. I was advised by Land Rover to do checks for leaks and other bits as they said that there was no known faults registered however did notice that the front left was down and said it could be a shock or the front valve block. He said to change the pipes over on the valve block and see if the driver side sits lower. So that I did and it stayed on the left so I changed the shock. I'm still having the issues and according to the Land Rover guy all of the ride height sensors are reading perfect. I must say that I have changed the height sensor on the passenger rear so this issue is clearly on the front passenger side. The only thing that is left really is the ride height sensor. I've run out of other things to replace. I have just ordered front and rear valve blocs so that I can rule them out for sure as the suspension seems to be working better after I cleaned them out |
Sun Sep 03 2017 10:18pm |
