Home > General > door mirrors to fold when locking car |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Short and easy answer is no... |
Sat Sep 02 2017 9:21pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
.....only if you have mirrors that are designed to auto fold, dip etc unfortunately.
Sat Sep 02 2017 9:41pm |
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 |
my mirrors fold if i push the button down and dip if i engage reverse, so i assumed it just needed programming to fold when locking the car |
Thu Sep 07 2017 9:25pm |
You can run a wire from the central locking to get the mirror to fold in, but that means it will do it every time it auto locks or you'll u want to lock the car when driving through dodgy areas Bodsys Brake Bible
Thu Sep 07 2017 10:03pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
Ppl have done the mod very easily on the jag X type so should be possible. |
Thu Sep 07 2017 10:14pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Mine fold when I lock the car with the fob? |
Thu Sep 07 2017 10:58pm |
and yours is a later model |
Fri Sep 08 2017 11:28am |
willv8 Member Since: 06 Aug 2017 Location: south Wales Posts: 16 |
Mine dip etc are they meamt to fold aswell? mines a 57 tdv8 if so how lol |
Fri Sep 22 2017 12:13am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Not from the key fob I'm afraid, but should from the rotary switch.
Fri Sep 22 2017 12:56am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Mine do not fold at all - would be nice if they did. 07MY RRS TDV6
Fri Sep 22 2017 1:34am |
Duplicate post 07MY RRS TDV6
Fri Sep 22 2017 1:38am |
My old pre-facelift did, just had to push rotary knob downwards to fold and push down again to unfold. I believe some may have had manually operated as opposed to electrically operated one's, as it was a 2009 UK spec. if that makes any difference. Cheers Col |
Fri Sep 22 2017 1:49am |
Mine fold manually. In Aust the spec of the vehicle was based on the engine - with the TDV6 being the poverty model. Next higher spec was attached to the petrol V8 and TDV8 then the top spec was attached to the Supercharged V8. There was no HSE etc.
Fri Sep 22 2017 7:42am |
Even in the UK there were a few things the petrol got than the diesel didn't.
Fri Sep 22 2017 11:44am |
