Home > Maintenance & Modifications > Pedal pox tuning |
willv8 Member Since: 06 Aug 2017 Location: south Wales Posts: 16 |
Sun Aug 20 2017 10:44pm |
Have it remapped as i had a box on my 2.7 and yes it did give more power but also a load more smoke out the rear and if you drove it from low speed and a higher gear then floored it it would go into limp mode so my advise is do not use them |
Mon Aug 21 2017 8:05am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
Just select first gear before pulling away. The gearbox defaults to second gear which gives the tardy, but luxury, slow get away. Also, the TDV8 can be a bit turbo lag prone at low revs. Use of the gearstick to select sport can avoid the lag because it drops a gear and lifts you in to the "wah-hey" rev range.
Mon Aug 21 2017 9:20am |
Thanks for the advice mate, I'm looking at alive tuning just got off the phone with them now.. The tuning boxes I was talking about only modify the pedals/responce they aren't an actual ecu etc adjustment. |
Mon Aug 21 2017 2:39pm |
Hi mate thanks for that always good to hear new info on the tdv8.. I'm booked in for a full major service and gearbox flush and filter change. with the best indy I'm my area promec) they also deal for alive tuning. The Pedal box I posted above isn't one of those engine tune boxes it plugs in to the pedal set up area (not sure where) and you can select about 4 different response types the throttle will give. Spoke to alive tuning they said a map will make a little bit of difference to it but won't eliminate the delay completely. |
Mon Aug 21 2017 2:46pm |
Mon Aug 21 2017 2:48pm |
Geoff noticed your from Cardiff aswell mate, where do you take yours for the service? Penarth road wanted £1600!!! |
Mon Aug 21 2017 3:04pm |
Check whether the gearbox flush is really a flush. You don't normally change the filter when flushing, you just connect the gearbox to the flush machine and pump the old oil through to be replaced with new oil. It seems that changing the filter isn't really of much benefit. The issue is the oil quality and the deposition of oil crud on the torque converter and clutches as the oil breaks down with use. Changing the oil early and regularly reduces the crud and so keeps the clutches etc happy. The filter doesn't seem to make much difference to this. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 21 2017 3:28pm |
I wonder how a box in the pedal helps overcome the physical lag of the engine. I guess it just takes the speed you move the pedal and tells the engine you've moved it quicker to get more response, in effect a kick down without you reaching the kick down switch on the pedal. Not sure how this gives better fuel economy as claimed. Sounds a bit snake oily to me... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Aug 21 2017 3:33pm |
Yes it's a complete flush and cleaning additive of some sort then new filter and oil, other garages I spoke with only mentioned draining what oil they could as they didn't have the machine to get it all out. Yeah those pedal box things do seem a bit 2 good to be true I might just see how the map does tbh... tried that sport and into first method earlier. Seems to work well, also flicked into sport to overtake much better pick up. |
Mon Aug 21 2017 8:23pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Save your money and just press the pedal harder. |
Mon Aug 21 2017 9:29pm |
Doesn't matter how hard I press, delay is there regardless .. Thanks for trying to save me money though |
Mon Aug 21 2017 10:22pm |
Ahh maybe force isn't the issue, you need to press it down more quickly
Tue Aug 22 2017 9:15am |
