Home > Technical > Fault Codes P006A-00 & P1247-00, Restricted Performance |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
This is from workshop manual, if you can decipher any of it and what it means it may help.
Sun Aug 20 2017 10:14am |
Mr M Member Since: 11 Nov 2016 Location: Liverpool Posts: 26 |
Thanks Col,
Sun Aug 20 2017 10:27am |
Dawen35 Member Since: 17 Aug 2017 Location: Conwy Posts: 8 |
What year is the car, the reason for asking is my2010 started with similar fault codes and is currently having its dpf filter removed as it was blocked solid |
Sun Aug 20 2017 3:12pm |
It's the same as yours, a 2010 3.0 ltr TDV6. How did you determine that it was the DPF that needed to be replaced? |
Sun Aug 20 2017 3:24pm |
The garage did, it was totally blocked solid. Symptoms of the drive was red triangle intermittently for a week and then total loss of power and a high pitch squeak on the last day |
Sun Aug 20 2017 3:27pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4319 |
Could be a split boost hose or manifold. Both very common |
Sun Aug 20 2017 4:16pm |
Thanks. Are both of these components easily accessible for me to check? Sorry but i'm not that mechanically minded so any pointers as to where both items are located so that I can check them for splits/leaks etc would be appreciated. |
Sun Aug 20 2017 5:10pm |
Update - The manifold has a split in it so a new one's been ordered and it's being fitted on Wednesday. Hopefully then, everything should be back to normal. |
Fri Aug 25 2017 7:21pm |
Further update - The manifold has been changed but I am still getting the same issues. The garage reckons its one of the EGR valves. They've suggested removing it, giving it a good clean and then re-fitting it to see if that sorts it out. Has anyone had any success with cleaning these as opposed to just replacing them?
Sun Sep 24 2017 9:05am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Can someone educate me please, I have been led to believe that the 3.0ltr TDV6 has vacuum operated EGR valves that are far less of a problem than the electronically activated ones on the 2.7.
Sun Sep 24 2017 9:24am |
3.0 cannot blank the EGR, as they are needed as part of the DPF regeneration...
Sun Sep 24 2017 10:23am |
Ok thanks.
Sun Sep 24 2017 11:07am |
What fault codes have returned? |
Sun Sep 24 2017 12:46pm |
I've only got a cheapo fault code reader but i've plugged it in and it's come-up with Code P006A which was one of the two codes that I was getting originally. When the garage replaced the manifold, they checked the MAF and said that was ok. Is there anything else that it is likely to be other than the EGR? |
Sun Sep 24 2017 1:28pm |
