Home > Faults & Fixes > Replace key fob covers on the newer style fobs
DrRob
If your key fob is shedding its skin then its very easy to change them. Buy new covers from LR for about £8 then follow Steve Norman's guide in this thread. Replace the battery too at same time.
You can also choose a matt or gloss version. Just ask the Parts guy in the dealership to show you the choice Thumbs Up
http://www.disco4.com/forum/topic158579.html
If I can do it then anyone can Thumbs Up
Both my keys now look brand new Bow down * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #533132 Fri Aug 18 2017 8:37am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
New Key Fob Cover fitting instructions
Thanks for the info Dr Rob i've just changed one of my cases today and followed the link to the guide, for others info I bought a genuine matt finish case from here - https://www.ebay.co.uk/itm/Range-Rover-Ran...fresh=true
and followed these clear instructions from the Discovery forum -
"No cutting or gluing required.
Take apart like you would to change the battery.
The circuit board is held in place by two small plastic posts sticking up from the case. On the original fob these have had the top slightly melted to form a blob which holds the board in place. Carefully lever the board next to the blob and it'll pop off the post. Lever one then the other.
Should the post break off, as they are very thin, then just pull it out of the board once it's out of the case. This gives you two holes in the board to aligne to the new posts on the new case.
I never bother melting the posts again, as the two halves of the fob hold it in place, which just snap together".
Post #540814 Tue Nov 14 2017 12:44pm
DrRob
Cool....piece of p*ss isn’t it? Thumbs Up * Current: 2024 D350 Defender 90 on coils!
Post #540853 Tue Nov 14 2017 6:12pm
