Home > General > Front end vibration
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Front end vibration
Over the last 6 months I've noticed an increasing vibration from the front noticeably when you come off a roundabout and accelerate! Vibration last as you accelerate but stops after you've straightened up ? Wheels are balanced properly (recently checked ) any thoughts welcome please . TDV8 2008
Post #532959 Wed Aug 16 2017 8:33am
Socast
With it being under aceleration it could be either a diff or driveshaft problem.
Post #532964 Wed Aug 16 2017 9:18am
Alfie
Ok ? Could anyone with this experience elaborate what the problem may be , appreciate all thoughts thank you .
Post #533085 Thu Aug 17 2017 8:40pm
Alfie
If I have a problem with either front diff or driveshaft what would it cost to replace / fix either just to give me an idea . The problem seems to be getting more noticeable but doesn't happen if I accelerate on a straight, just when I boot it from coming off a round about. Thanks
Post #537765 Sun Oct 08 2017 4:28pm
Have you had a 4 wheel alignment check done? Incorrect alignment can cause this. Also check tyre pressures. I've found that pressure imbalance across the axle can cause vibrations. Slightly low pressure will also cause it. 2012 SDV6 - it's missing a couple of cylinders
Post #537768 Sun Oct 08 2017 4:34pm
Alfie
Hi yes had a full wheel alignment carried out when I had front lower wishbones replaced earlier this year . Also tyre pressures Are spot on . I'm trying rack my brains to remember if I had this vibration before I had the wishbones done back in February and to be honest I don't think I did 🤔 Certainly not as noticeable as it is now .... I wondered if It might be the front ARB bushing as it is more noticeable when accerlating off a bend .... at a lost as to what it could be
Post #537771 Sun Oct 08 2017 4:46pm
How many miles on the vehicle? 2012 SDV6 - it's missing a couple of cylinders
Post #537787 Sun Oct 08 2017 6:42pm
Eaters
It doesn’t sound like th3 same problem I had but might be worth a read of this so that you can rule it out.
http://www.rrsport.co.uk/forum/topic44617.html
Certainly worth checking the oil in the front diff. If it’s all black and grungy then you are fairly certain that there’s a problem in there. If not look elsewhere.
Have you swapped any wheels around? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #537795 Sun Oct 08 2017 7:19pm
Alfie
Hi , it's just hit the 100 thousand this week . It's a 2008 tdv8
Post #537797 Sun Oct 08 2017 7:23pm
Alfie
Hi Eaters , yes had front to rear swap because of the wear on the fronts but this vibration issue was present before I had that done and both front wheels were rebalanced . I'm considering having the front diff oil inspected now just to see condition of the oil . There's no noise as described in your post . Thanks
Post #537800 Sun Oct 08 2017 7:36pm
Eaters
Hi Alfie
The question about the wheel swap was because there was a comment on here recently about keeping wheels where they were (especially I think if asymmetrical tyres but I could have been dreaming that). I recall it was not so much the wheel balance but the wear on each tyre being slightly different. Even as I write this I wonder if I’ve just had too much to drink. But I’ve said it now anyway. If the problem was there before the wheels were swapped then it’s not that. Robin
Gone:
MGZTT 190 2.5
Post #537818 Sun Oct 08 2017 11:06pm
Johnski
On the official LR Service sheets and agreement, changing wheels around is part of all standard service A & B.
I did say not to bother on last service due to new tyres, but I haven't actually noticed if they have moved them as stated, as a requirement too. John
Post #537821 Sun Oct 08 2017 11:18pm
Alfie
Passed MOT today without any issue . Having consulted a local Indy it seems highly likely I have a worn driveshaft ! Which was advised in an earlier reply to my post . Very grateful to all that replied with help I will keep you informed how I go on as I will now have the driveshaft replaced
Post #538025 Tue Oct 10 2017 8:48pm
jenko2005
Wales 2006 Range Rover Sport Supercharged Zambezi Silver
mines just gone in with a similar problem 61 plate 27,000 miles 3.0 tdv6 happens around 1000-1500 rpm turning into junctions and going around roundabouts been told its 1 of 4 things glad ive got a LR warranty however starstone cardiff been unavailable to diagnose it for the last 8 months or more gone back to where i bought it from
propshaft
transfer box
torque convertor
gearbox
Post #538038 Tue Oct 10 2017 11:05pm
Alfie
Going in for propshaft fix tomorrow ( centre bearing rubber split possibly damaged centre bearing) my local Indy specialist is replacing centre bearing. Hopefully this will fix the vibration I experience when coming of roundabouts and booting it !! Somehow I doubt it will cuz I suspect it's the torque converter but will let you know this time tomorrow 🤞
Post #542129 Wed Nov 29 2017 7:09pm
